Thank’s for help, but I uninstall V9.0 year ago ? (:)) and remove this file, I can’t waste time for this.
BTW:
C:\Users\tbarw>tasklist /v /fi “IMAGENAME eq kicad.exe”
ERROR: Invalid argument/option - ‘eq’.
Type “TASKLIST /?” for usage.
I tried to reproduce the problem, but my environment did not reach the same state as yours. In other words, I was able to open the project created in 8 with 9.0rc and save each one. Were you running two KiCADs at the same time? What were the results of the command prompt to check the permissions and free disk space?
Also, if you could reproduce the problem by creating the same state including the backups folder, we might be able to find something. Can you make it public?
Please change the double quotes, they seem to be different on this forum website.
For more information, run the command TASKLIST /? and check the syntax.
Did the other commands produce the results you expected?
Just to let you know, is this an environment where OneDrive is installed? And is the network speed fast?
I don’t use OneDrive in my environment.
By the way, if you copy a project created in 8.0 to a location other than MyDocument, for example to a new folder called C:\KiCadTest\ and it’s successful, does that mean the behavior of OneDrive or something similar could be affecting it?
I don’t use onedrive.
Results from console is fine:
C:\Users\tbarw>tasklist /v /fi "IMAGENAME eq kicad.exe"
Image Name PID Session Name Session# Mem Usage Status User Name
CPU Time Window Title
kicad.exe 1200 Console 1 1 511 244 K Running RAZER\tomek
echo %USERNAME%:15:27 estat-główna-poprawiona-8 — Edytor obwodów drukowanych
tomek
C:\Users\tbarw>
C:\Users\tbarw>dir /q C:\Users\tbarw\Documents\kicad9_pliki\estat-przednia-poprawiona-4\
Volume in drive C is Blade 15 SSD
Volume Serial Number is D38A-1832
Directory of C:\Users\tbarw\Documents\kicad9_pliki\estat-przednia-poprawiona-4
30.12.2024 10:45 <DIR> RAZER\tomek .
01.01.2025 00:36 <DIR> RAZER\tomek ..
02.09.2023 08:42 493 435 RAZER\tomek bez_nazwy.kicad_pcb
02.09.2023 08:42 120 455 RAZER\tomek bias_sch.kicad_sch
30.12.2024 10:45 <DIR> RAZER\tomek estat-backups
02.09.2023 12:48 63 762 RAZER\tomek estat-przednia-poprawiona-4-B_Cu.gbl
02.09.2023 12:48 4 823 RAZER\tomek estat-przednia-poprawiona-4-B_Mask.gbs
02.09.2023 12:48 185 269 RAZER\tomek estat-przednia-poprawiona-4-B_Silkscreen.gbo
02.09.2023 12:48 1 154 RAZER\tomek estat-przednia-poprawiona-4-Edge_Cuts.gm1
02.09.2023 12:48 26 948 RAZER\tomek estat-przednia-poprawiona-4-F_Cu.gtl
02.09.2023 12:48 4 444 RAZER\tomek estat-przednia-poprawiona-4-F_Mask.gts
02.09.2023 12:48 12 022 RAZER\tomek estat-przednia-poprawiona-4-F_Silkscreen.gto
02.09.2023 12:48 2 477 RAZER\tomek estat-przednia-poprawiona-4-job.gbrjob
02.09.2023 12:08 456 RAZER\tomek estat-przednia-poprawiona-4-NPTH.drl
02.09.2023 12:08 1 827 RAZER\tomek estat-przednia-poprawiona-4-PTH.drl
27.12.2024 23:32 699 939 RAZER\tomek estat-przednia-poprawiona-4.kicad_pcb
27.12.2024 23:32 1 318 RAZER\tomek estat-przednia-poprawiona-4.kicad_prl
22.12.2024 11:19 14 610 RAZER\tomek estat-przednia-poprawiona-4.kicad_pro
02.09.2024 19:24 76 653 RAZER\tomek estat-przednia-poprawiona-4.kicad_sch
02.09.2023 08:42 7 496 224 RAZER\tomek estat-przednia-poprawiona-4.step
03.09.2024 19:28 8 095 218 RAZER\tomek estat1.step
22.12.2024 11:12 323 RAZER\tomek fp-lib-table
02.09.2023 12:13 247 455 RAZER\tomek LED.kicad_sym
30.12.2024 10:45 <DIR> RAZER\tomek LED_SMD.pretty
30.12.2024 10:45 <DIR> RAZER\tomek Library.pretty
30.12.2024 10:45 <DIR> RAZER\tomek Library1.pretty
02.09.2023 08:42 82 804 RAZER\tomek negative.kicad_sch
02.09.2023 12:06 87 980 RAZER\tomek New_Library.kicad_sym
30.12.2024 10:45 <DIR> RAZER\tomek packages3D
02.09.2023 08:42 74 640 RAZER\tomek positive_sch.kicad_sch
02.09.2023 08:42 71 847 RAZER\tomek power_hv_sch.kicad_sch
02.09.2023 08:42 297 029 RAZER\tomek signal_part.kicad_sch
22.12.2024 11:12 715 RAZER\tomek sym-lib-table
02.09.2023 08:42 71 147 RAZER\tomek untitled.kicad_sch
22.12.2024 11:03 696 864 RAZER\tomek _autosave-estat-przednia-poprawiona-3.kicad_pcb
22.12.2024 11:12 1 575 RAZER\tomek _autosave-estat.kicad_prl
22.12.2024 11:12 5 450 RAZER\tomek _autosave-estat.kicad_pro
30 File(s) 18 938 863 bytes
7 Dir(s) 140 870 901 760 bytes free
C:\Users\tbarw>cacls C:\Users\tbarw\Documents\kicad9_pliki\estat-przednia-poprawiona-4
C:\Users\tbarw\Documents\kicad9_pliki\estat-przednia-poprawiona-4 ZARZADZANIE NT\SYSTEM:(OI)(CI)(ID)F
RAZER\tomek:(OI)(CI)(ID)F
BUILTIN\Administrators:(OI)(CI)(ID)F
C:\Users\tbarw>dir /q %USERPROFILE%\Documents\KiCad\
Directory of C:\Users\tbarw\Documents\KiCad
01.01.2025 01:06 <DIR> RAZER\tomek .
01.01.2025 01:07 <DIR> RAZER\tomek ..
18.01.2024 16:43 <DIR> RAZER\tomek 8.0
01.01.2025 01:06 <DIR> RAZER\tomek 9.0
0 File(s) 0 bytes
4 Dir(s) 140 870 770 688 bytes free
C:\Users\tbarw>dir /q %USERPROFILE%\Documents\KiCad\9.0\
Directory of C:\Users\tbarw\Documents\KiCad\9.0
01.01.2025 01:06 <DIR> RAZER\tomek ..
18.01.2024 16:43 <DIR> RAZER\tomek 3dmodels
18.01.2024 16:43 <DIR> RAZER\tomek 3rdparty
18.01.2024 16:43 <DIR> RAZER\tomek footprints
18.01.2024 16:43 <DIR> RAZER\tomek plugins
18.01.2024 16:43 <DIR> RAZER\tomek projects
01.01.2025 01:06 <DIR> RAZER\tomek scripting
18.01.2024 16:43 <DIR> RAZER\tomek symbols
18.01.2024 16:43 <DIR> RAZER\tomek template
0 File(s) 0 bytes
10 Dir(s) 140 870 770 688 bytes free
C:\Users\tbarw>cacls %USERPROFILE%\Documents\KiCad
C:\Users\tbarw\Documents\KiCad ZARZADZANIE NT\SYSTEM:(OI)(CI)(ID)F
C:\Users\tbarw>cacls %USERPROFILE%\Documents\KiCad\*
C:\Users\tbarw\Documents\KiCad\8.0 ZARZADZANIE NT\SYSTEM:(OI)(CI)(ID)F
C:\Users\tbarw\Documents\KiCad\9.0 ZARZADZANIE NT\SYSTEM:(OI)(CI)(ID)F
ETC
All is fine. But V8 work and v9 can’t create any files.
Is the output of echo %USERNAME% correct?
Do you see a long string of text instead of tbarw? tomek?
Yeah, why the user’s home directory c:\users\tbarw is different to the user name tomek?
cacls is a deprecated command. It seems that it is better to check with icacls now.
This command has been deprecated. Please use icacls instead.
Are you in an environment where you previously did the following?
- You performed special tasks such as resetting your password.
- You created both a Microsoft account and a Windows local account.
- You switched between a Microsoft account and a Windows local account.
- You used a non-alphabeta character string when creating a user name.
If you are in a special environment like the above, it would be a good idea to take a closer look at the behavior of file/folder ownership and process management in your OS rather than KiCad 8.0 or 9.0rc.
I think I can solve the problem if I can reproduce your environment, but I would appreciate any tips on how to create that environment.
Everything in the console output looks right to me.
The only explanation I could think of is an antivirus, or some other program messing with KiCad 9 somehow.
So if you have such programs, try disabling them or adding KiCad 9 to exception list.
If the result of the tasklist command contains the string estat-główna-poprawiona-8, it may be different from the project folder you checked with cacls.
If the result of echo %USERNAME% contains estat-główna-poprawiona-8, then that’s a special username.
No, is fine:
C:\Users\tbarw>echo %USERNAME%
tomek
I don’t know.
My home directory is “tbarw” and user name is “tomek” and it’s always been like that - from what I remember. On the other hand V8 works so it can’t be a problem - unless it’s for V9?
Past similar cases?
“error 5:access denied” on Windows with Antivirus software
It seems necessary to check the type of antivirus software installed and the antivirus software logs.
I looked for examples. It seems that having different user names and directory names is not a problem.
https://www.elevenforum.com/t/user-name-different-that-file-explorer-name.16806/
Although it is not directly related to this incident, when trying out RC, it would be a good idea to also keep an eye on the comments on the following topics.
