The 9.0.0 PCB: I want properties and appearance panels ALWAYS ON.
How can I impose this? In properties it seems there is nothing about.
up? Is it a bug then?
You may be a victim of the .kicad_prl file bug: PCB Pads, & Traces gone after update to KiCad 9.0.0 - #6 by craftyjon
May be but in that post it seems no one noticed that you cannot have the panels always on. There is no way and itâs really annoying, because itâs useless and needless each time to go to menu > view > panels and every time turn them on.
And there is not anything on preferences.
it looks like the very bad idea to hide the markers made by DRC that one should enable them. It seems made by someone never worked.
Do you have at least tried to delete the *.prl file?
Normally the on/off state of the panels should be saved by kicad, so at next kicad start the complete GUI can be restored. Thatâs the reason you canât find a preferences setting.
This works on my system correctly.
If this doesnât works on your system: file a bugreport with good description. And with a example project, as this might depend on some (false/not working) project settings.
I can . . I turn them on, shut down the PCB Editor, shut down KiCad v9.0.0 , start KiCad open the Project, open the PCB Editor and they are still on/showing.
Application: KiCad x64 on x64
Version: 9.0.0, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22631), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) UHD Graphics, 4.6.0 - Build 32.0.101.5768
Date: Feb 19 2025 17:46:53
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
Encoded кΊä¸: D0BACEA9E4B888 (sys), D0BACEA9E4B888 (utf8)
Never worked and itâs not working. I will try the solution to delete that .prl file while Iâm waiting for the 9.0.1 that I hope it will be available as soon as possible.
In schematics editor works, in PCB not at all.
The *.prl file (in the project directory) was a red herring.
The setting for panels on/off is saved in the file âpcbnew.jsonâ. The file is located in the general kicad user folder (on windows: c:\Users\user_xxxx\AppData\Roaming\kicad\9.0\pcbnew.json).
That file contains a section âAUIâ with settings for âshow_layer_managerâ / âshow_propertiesâ.
This file should be updated (time stamp) at every kicad closing action. (please check if this update happens and if the settings reflect the last state of the GUI).
This check would give a indication:
- if the problem is during saving the last gui state: âpcbnew.jsonâ would not have the correct setting
- if the problem is during starting the next kicad session and restoring the last gui state: âpcbnew.jsonâ would have the correct setting, but the restoreing/loading would not work
As this is a unusual behaviour I guess it depends on some specific characteristics on your computer/workflow. (otherwise this behaviour would have been reported a long time ago). So probably all additional informations about your computer system are needed to find the cause why itâs not working on your system.
(for instance: installed as different user/admin? working on a network drive? working with multiple monitors? moved the panels to different monitors? Is the computer located on top or below the desk? Which radio station is running? color of your pets/dogs/cats?)
pcbnew.json is indeed updated when I close KiCAD (time stamp is correct) but the AUI is wrong it saved âfalseâ when it must be âtrueâ.
IF I manually change the value to TRUE, opening pCB everything is fine.
Once I just close KiCAD, it overwrite the JSON writing âFALSEâ. Very annoying
NOTE the version 8 had not any issue like this.Just version 9 and once installed and imported settings from version 8, it didnât respect the settings.
NOTE 2: not any other user installation else. What I t was in version 8 is in version 9.
âauiâ: {
âappearance_expand_layer_displayâ: true,
âappearance_expand_net_displayâ: false,
âappearance_panel_tabâ: 0,
ânet_inspector_widthâ: -1,
âproperties_panel_widthâ: 20,
âproperties_splitter_proportionâ: 0.38205981254577637,
âright_panel_widthâ: 498,
âsearch_panel_dock_directionâ: 3,
âsearch_panel_heightâ: 200,
âsearch_panel_widthâ: 1684,
âshow_layer_managerâ: false,
âshow_net_inspectorâ: true,
âshow_propertiesâ: false,
âshow_searchâ: true
This limits the issue to the kicad closing/saving process.
Please open a bugreport, with as many details as possible. As said I have not seen a issue about this before. corrected due to the answer below
Very annoying
Sadly thatâs the nature of bugs.
There is already a known issue in 9.0.0 about this that is fixed for 9.0.1. You can wait a few weeks for that release or else try a testing build. As was already pointed out, the prl thing is not related (panel settings are not stored with the project settings)
Iâm trying the 9.0.1 RC1. This bug seems solved.
