could someone post screenshots of parameters required for Gerbers and drill files for PcbWay?
Examples I have found seem to differ with version 9 than whats available from PcbWay website
Thanks
Thanks
You can use the PCBWay plugin to generate the files and submit. But nothing has changed compared to previous KiCad versions.
It’s just a handful of numbers, and it’s not very difficult to interpret them. I even think that looking at the numbers on their website, and translating them to how KiCad interprets similar features is a good practice to get a better idea of why these numbers are what they are.
Updated: 06/19/2025 3 A.M. PST (USA)
KICAD PCB EDITOR GERBER/DRILL FILES EXPORT
(‘QUICK TURN PCB 7 LAYERS ONLY’) COMPATIBLE INFO:
[PROJECTNAME]-B_Cu.gbr
[PROJECTNAME]-B_Mask.gbr
[PROJECTNAME]-Edge_Cuts.gbr
[PROJECTNAME]-F_Cu.gbr
[PROJECTNAME]-F_Mask.gbr
[PROJECTNAME]-F_Silkscreen.gbr
[PROJECTNAME]-PTH.drl
FILENAME EXTENSION RENAME:
[PROJECTNAME]-B_Cu.GBL
[PROJECTNAME]-B_Mask.GBS
[PROJECTNAME]-Edge_Cuts.GK0
[PROJECTNAME]-F_Cu.GTL
[PROJECTNAME]-F_Silkscreen.GTO
[PROJECTNAME]-PTH.DRL
(OPTIONAL EXCELLON FORMAT)
[ROJECTNAME]-PTH.XLN
NOTE: USE ONLY .DRL FILENAME EXTENSION IN KICAD ORIGINAL DESIGN
IF MANUFACTURER PREFERS/REQUIRES EXCELLON DRILL FORMAT
ONLY AFTER GERBER EXPORT RENAME FILENAME EXTENSION TO:
.XLN (EXCELLON DRILL FILE EXTENSION FORMAT)
EXAMPLES W/NUMERICAL LAYER IDENTIFER:
[PROJECTNAME]_1-EDGE.GKO
[PROJECTNAME]_2-DRILL.DRL
[PROJECTNAME]_3-SSTOP.GTO
[PROJECTNAME]_4-SMTOP.GTS
[PROJECTNAME]_5-CPRTOP.GTL
[PROJECTNAME]_6-CPRBTM.GBL
[PROJECTNAME]_7-SMBTM.GBS
[PROJECTNAME]-2-DRILL.XLN
PACKAGE/ZIP ALL FILES:
[PROJECTNAME]_GBR.ZIP
KICAD GERBER VIEWER IMPORT FOR EXPORT TO PCB EDITOR:
Open ZIP File [PROJECTNAME]_GBR.zip …
Export to PCB Editor …
Filename: [PROJECTNAME].kicad_pcb
Layer Selection:
[PROJECTNAME]_CopperBottom → B.Cu
[PROJECTNAME]_CopperTop --? F.Cu (OPTIONAL)
*[PROJECTNAME]_DrillHoles → Hole Data (DO NOT EXPORT)
[PROJECTNAME]_SilkScreenTop → F.SilkS
[PROJECTNAME]_SolderMaskBottom → B.Mask
[PROJECTNAME]_SolderMaskTop → F.Mask
[PROJECTNAME]_BoardOutline → Edge Cuts
*(Export as Separate Reference File
Filename: [ProjectName_Drill].kicad_pcb)
SUGGESTED PCB MANUFACTURERS:
JLCPCB
Elecrow
NextPCB
https://www.pcbway.com/
PCBWay
EXAMPLE OF MY OVERDUB MIXER GERBER FILES
DOWNLOAD LINK:
OVRDUB_GBR.zip (500.2 KB)
THIS IS A FULLY WORKING PCB MANUFACTURED KICAD 9 PROJECT
AVAILABLE AT MY IFX KICAD WEBSITE
TEST SCHENATIC W/SPICE SIMULATION
SCHEMATIC W/NETLIST EXPORT
