As I said, this is what you can do now:
Unless you want to implement this yourself it probably won’t be done (I can already imagine Wayne’s reply ;-)), but feel free to drop by on the bugtracker and tag it as wishlist item…
The libs have to be ‘linked’ individually anyway currently for the modern version. There is no search path per see anymore, like you currently see it for EEschema. Afai-aware KiCAD never employed the concept of - just point it at a folder and it will try to load all libs that it finds in that folder - as even for EEschema you have to link each lib into the program individually - even though you set up the search path beforehand.
Good luck though.
