Improved OpenEMS interface
Found a new project that reduces export and import error for simulation with openEMS to a minimum
tested the examples as well as some structures I had already tested on TDR in real world. Looks good.
Only limitation it only works for PCB structures, but even can reduce work for antennas or other 3D near/far field structures.
Now I need a spare week to try this. The instruction in the linked page are much clearer than I have seen before
Hmm… Old thread, so should this be moved to a new thread? It is kinda long for people to read through if the bottom is more relevant.
Moved. Plugins is not quite accurate, but discussion about OpenEMS is KiCad related
