import pcbnew
from pcbnew import *
b=pcbnew.GetBoard()
new_arc=PCB_SHAPE()
new_arc.SetShape(SHAPE_T)
p1= wxPoint(203200000, 127000000)
md= wxPoint(221160512, 134439488)
p2= wxPoint(228600000, 152400000)
# new_arc.SetArcGeometry(aStart: 'wxPoint', aMid: 'wxPoint', aEnd: 'wxPoint')
new_arc.SetArcGeometry(p1,md,p2)
# new_arc.SetStart(p1)
# new_arc.SetMid(md)
# new_arc.SetEnd(p2)
new_arc.SetWidth(250000)
new_arc.SetLayer(pcbnew.F_SilkS)
b.Add(new_arc)
# pcbnew.SaveBoard("./test.kicad_pcb",b)
Here a sample code that should work…
But the result is a line instead of an arc.
The format inside the file is ‘gr_line
’ instead of ‘gr_arc
Moreover, executing the Save code (last commented line), pcbnew just crashes.
I also found a nasty error.. designing a simple 90 deg Arc with the Gui and pressing Edit and simply confirm the Arc will rotate… probably because Start point is mangled with Center point in the pcbnew code…
Application: KiCad PCB Editor (64-bit)
Version: (5.99.0-11630-gc5e195bdff), release build
wxWidgets 3.1.5
libcurl/7.74.0-DEV Schannel zlib/1.2.11
Platform: Windows 10 (build 18363), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Aug 3 2021 21:00:05
wxWidgets: 3.1.5 (wchar_t,STL containers)
Boost: 1.75.0
OCC: 7.5.0
Curl: 7.74.0-DEV
ngspice: 34
Compiler: Visual C++ 1928 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
test.kicad_pcb (2.1 KB)
arc-dwg.kicad_pcb (2.1 KB)
