Yep, maybe I misunderstood but I meant just draw a zone using using the imported shape as a guide to where to place the vertices
Howto connect polygon to net
As already is clear, b) isnât possible without someone writing a script for it. BTW, I was confused about talks about âpadsâ. What you describe here is a copper zone, not a pad. A simple script could do that, but such script doesnât exist ATM.
But the case a) can be done easily at least with the latest nightly builds and the upcoming 5.0 (which we all wait for eagerly). I donât remember anymore how well 4.0.7 supports it, but the development version supports attaching net for a zone. Just draw a filled polygon shape to a copper layer - when you start, a properties dialog pops up and you can select a net amongst other properties. That works in the Board Editor - In the Footprint Editor you can draw a filled polygon and âCreate Pad from Selected Shapesâ if you need a reusable footprint with a polygonal pad. And it looks like you can import a DXF file in the Footprint Editor, too.
Hi eelik,
I updated my version of Kicad to the latest, and yes, I can draw a polygon on a copper layer as a zone and attach it to a net, that will do the job for now.
I had a quick look at the Footprint Editor, but could not see a way to turn on the dwgs.Use layer (to import .DFX into) ⌠as I can in the pcb_new ⌠all the layers from that one down to Margin are ghosted out, as is the copper layers ⌠so I canât even draw a polygon in a copper layer âŚ
Yes, itâs a bit unintuitive and should be changed IMO in some way or another. But you should be able to use the silk or other available graphic layer. You should be able to import a DXF there draw a polygon on another graphic layer and make it a pad, in the latest nightly builds such a pad is also automatically moved to a copper layer. Earlier it required some extra steps, nowadays it works pretty much automatically - except that itâs not obvious and intuitive that you have to first draw on a non-copper layer. (I assume you mean a nightly build with the âlatestâ version.)
When you open your PCB file in some text editor, you can get a better understanding of how things work, you can then manually change the netname, coordinates of some points, arcs and stuff like that, and then go back to gui mode and see what happens, helped me a couple of times
