That’s the reason why I make my own Library. If you see, a resistor would fit better the other way round, you press “r” to rotate it. But it does not rotate. It starts dancing around pin 1. Thats simply idiotic!
The reason for this is that there is no other way to get the coordinates for the pick and place…
I think you could just place the part any way you wanted, and either the router swapped pins automatically or from command.
