In any KiCad window, look for “Configure Paths…” in the preferences menu. Look to see what path is configured to KISYS3DMOD and check to see that the path exists on your system. If it exists, check to see that LED_THT.3dshapes/LED_D3.0mm_IRGrey.wrl exists within that path.
If it doesn’t, you may not have installed the 3D objects.
The variable is set to /usr/share/kicad/modules/packages3d/
root@neptune1:/usr# cd share/kicad/modules/packages3d
bash: cd: share/kicad/modules/packages3d: No such file or directory
root@neptune1:/usr# pwd
/usr
root@neptune1:/usr/share# cd modules
bash: cd: modules: No such file or directory
root@neptune1:/usr/share# ls -Fd * | grep /$
GConf/
GeoIP/
GraphicsMagick-1.4/
ImageMagick-6/
PackageKit/
QtCurve/
X11/
a2ps/
accounts/
zsh/
zuluCrypt/
You will need to install the libraries package. I would guess it will be called kicad-packages3d or similar (search for kicad* using your package manager)
root@neptune1:/usr/share# apt-cache search kicad-packages3d
kicad-common - Old common files used by kicad - Transitional Package
kicad-libraries - Virtual package providing common used libraries by kicad
kicad-packages3d - 3D models for 3D viewer in KiCad’s Pcbnew and Footprint Editor
root@neptune1:/usr/share# apt-cache madison kicad-packages3d
kicad-packages3d | 5.0.0-2~bpo9+1 | Index of /debian stretch-backports/main amd64 Packages
kicad-packages3d | 5.0.0-2~bpo9+1 | Index of /debian stretch-backports/main i386 Packages
I will install that deb package and then return here to see if you want me to restart kicad.
Okay, I just added 314 MiB of files from that deb package, kicad-packages3d (5.0.0-2~bpo9+1).
I didn’t close kicad, just closed and then reopened pcbnew.
Here it is:
[https://ibb.co/ivk0y0](3D Board view of BuildElectronicCircuits’ Kicad demo. #1)
