Sounds excellent. Thanks!
Here is another example which does not work as expected. This is not a block, but I have connected a ground power symbol to an IC just by moving it there. Then when I drag it away (hoping to get a visible wire; similar to ârubber bandingâ in other EDA tools) the IC symbol glues to the ground symbol and moves with it.
I canât tell from the highlight colours in the second action but its possible you had an additive selection and the GND was added to the amp so two symbols were selected. What if you clear the selection in between with ESC? Though you shouldnât have to methinks.
I think you expect that dragging the ground symbol would add a wire. KiCad does not work that way (at least not now).
KiCads way can be used for good. Think of the situation turned around.
Example if you have both power supply pins directly connected to a power symbol. You can now move the OPA together with the power symbols if you need to.
The nightly builds do add a wire.
Cheers,
Jeff.
I tried doing this several times. Mostly just clicking on the ground symbol but also just identifying it alone with a small block. The results always the same.
Yes I can see that would be a useful capability. But if I wanted to do that, my first thought would be to block the op amp together with the power symbols and drag or move all together.
Between this comment and another previousâŚI think maybe I should install the newest nightly. (few minutes elapsed) Now I did so. Sort of funny I would not expect to immediately see the difference but right away I see it. First impression is that I like the way identified symbols light up. And yes I get ârubber bandingâ when repeating what I showed in my last .gif. So this looks pretty good.
Application: Eeschema
Version: (5.99.0-657-g792e841ec), release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Build date: Jan 7 2020 22:27:11
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
