Thank you very much for telling me about that bug. That was indeed the problem. Maybe I’ll be able to continue with KiCad 9 … if I can manage to workaround the custom footprints problem.
Report back after you’ve moved the files to a local drive.
Hi dsa-T. I have the same problem but am not sure what you are showing in the screen capture above. How do you enable them back exactly?
You have to click on the “eye” icon
if the eye has a line crossing it and is grayed out it is disabled, you should just try to disable and enable everything again.
