Footprint editor : multi pad edit - redux!
HI, no, not that. example If I have 48 QFN pads and I want to change all 48 at once to a different something like say, slightly smaller solder mask expansion. , then the method as described in the https://forum.kicad.info/t/select-multiple-pads-and-bulk-edit-the-properties/21599 using the file works fine. However it could be easier. That is - open an inplace editor with a REGEX functionality so that I can enter the regex, get the desired changes and close and it is done…
