Extra text on a print, SOLVED
I am happy to be proven wrong on this! For the first time I was able to print a usable PDF of the board outline, part outlines, vales and solder pads. Without references and values being doubled.
V8. Include layers: Edge Cuts
Plot on all Layers: F.Silkscreen, F.Mask
I did include drill marks: actual size. But they seem to be obscured by the mask shapes.
My celebration was short lived. Clicking on the PDF or SVG (I plotted both) opens it in Firefox, where the text is not doubled. Imported either file into Corel, the doubled text is back. AND the cleaner text is locked.
I dragged everything that wasn’t locked away from the locked text and it did separate. But the unlocked text has a 0.425 pt outline on each letter. This looks bloated and odd.
Can I address this too? Yes. Will I? Probably. Just more steps in the process that seem needless. Especially when I’m always under pressure to deliver.
Which KiCad version do you use?
It’s the vector graphics editor’s problem that it renders 0-opacity text (needed for search function), but there’s a workaround implemented in KiCad 8.0.4+.
See:
Try harder to keep searchable text hidden in SVG exports (e1ffd956) Ā· Commits Ā· KiCad / KiCad Source Code / kicad Ā· GitLab
Very interesting! I wonder if Inkscape or Illustrator would have the same issue. Maybe I’ll try.
Glad to know there’s a fix coming!
What do you mean? KiCad 8.0.4 was released in Jul 17. You just have to upgrade.
Still no luck. 8.0.4 Plot SVG with Edge.cuts F.mask and F.silkscreen
File open in Edge on the left and Corel on the right.
I also plotted a PDF with same selections. This opens fine in Firefox and Edge. Won’t open at all in Corel. I’ve had to force quit Corel 3 times in task manager.
I’m still using Corel 17, maybe it’s time to update.
Try opening these files and tell which ones render correctly:
  1. pic_programmer-Edge_Cuts.svg
  2. pic_programmer-Edge_Cuts_mod1.svg
  3. pic_programmer-Edge_Cuts_mod2.svg
  4. pic_programmer-Edge_Cuts_mod3.svg
Sure thing!
Mod 1 and Mod 2 open correctly.
