Errors when using Freecad kicad-StepUp WB to upload my PCB
Just started using Kicad 8 (8.0.0) after having used previous versions for a while. Need to import my PCB into Freecad (0.21.1), bus suddenly get errors. Boards versions that I made in the past (say, a year ago or so) do load. The StepUp workbench is the latest version (11.5?)
Running the Python command ‘ksuToolsOpenBoard’ failed:
  • File “C:\Users\maxim\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod.\kicadStepUpCMD.py”, line 1212, in Activated*
  • kicadStepUptools.onLoadBoard()*
  • File “C:\Users\maxim\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod.\kicadStepUptools.py”, line 6905, in onLoadBoard*
  • mypcb = KicadPCB.load(name) #test parser*
  • File “C:\Users\maxim\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod.\fcad_parser\kicad_pcb.py”, line 101, in load*
  • return KicadPCB(parseSexp(f.read().decode(“UTF-8”), quote_no_parse)) # maui*
  • File “C:\Users\maxim\AppData\Roaming\FreeCAD\Mod\kicadStepUpMod.\fcad_parser\sexp_parser\sexp_parser.py”, line 798, in parseSexp*
  • assert stack, “Trouble with nesting of brackets”*
If you are going to use v8 at least use the last released patch level v8.0.9.
Not that easy. I am using portable Kicad and portable Freecad… They don’t have all versions.
Well in that case don’t say we didn’t warn you if you hit a bug that was fixed later. The first release of a new version is often problematic, which is why some like me are waiting for 9.0.1 or .2.
Also wasn’t Freecad 1.0 released recently after decades of 0.something?
Just tried Kicad 9.0.0 and get the same errors…
This version of Freecad now only USED to work with my pcbs, but also STILL works with my 1-2 years older files.
Hopefully someone who knows Freecad can help.
would you please post your kicad SteUp version? Is that the latest?
Would it be possible to have the pcb file which is failing? Or a stripped version which is still failing? Eventually if you prefer you can send it to me in PM
Maurice (author of kicad StepUp wb)
Could it be something like in this thread?:
Thanks! I was waiting for you to see my topic, because there was the same error in another topic on this forum, but it never got solved, unfortunately.
Sorry, but i can’t figure out how to PM my pcb file.
As for StepUp it is the latest version: 11.5.6. Also, as I mentioned, it opens well my last year design files.
You have been promoted a bit, you should be able now. Click on the avatar of the user.
@maxim-lee
it should now be fixed w/:
please update kSU WB and test it
Thank you! Worked like a charm!
If you do not mind: what was the problem? I assumer I could manually edit my file, but was not sure what to fix.
P.S. Update to 11.5.7 is the solution.
@maxim-lee
the issue was related to a property field inside the kicad_pcb file format.
The parser was failing with a double backslash inside the field.
(property "Datasheet" "d:\\mydir\\myfile" .....
Now it can handle this case.
