DIP pads on B.Cu only
And I forgot to mention onboard connecors, pin headers, jumpers and the like where you have the same problem.
Instead of embarking on a large scale creation of one sided footprints, how about modifying your workflow to hide F.Cu during the initial routing phase, and then turn on F.Cu for the remaining connections, being mindful of what you are drawing traces between.
If the physical board is still retrievable, can you simply put a tooth pick or paper clip under the socket to raise it up enough to be able to solder the pins on the top?
Working with the rule-out area seems to me the best way to go. Before starting to rout, I would define those for all concering components, such as IC sockets, on-board connectors and so on, and I’ll be safe.
Thanks to you and all other contributors. I am sure now that I didn’t overlook anything obvious.
