Well, it is not my intention to disturb or something like that. I do not want cause extensive repost the question that has already been resolved. I apologize for the misunderstanding is that sincerely to create the spiral that need it slipped from my hands light years.
Perhaps if Joan, or otrousuario friend of charitable soul could create me the zip file so as not to continue taking away your valuable time, you would appreciate forever.
Specifications are
for a circular PCB; = 15.5 mm perimeter
Spiral top thickness (the minimum allowed) 0,2 mm
separation of spiral lines (0.1 mm) or 0,3
number of turns: 8 spirals
sense of turns and direction of a clock (sa the same)
It is also important to start from the outside in
separating the perimeter of the PCB with respect to the first line of the spiral: 0.2 mm or 0,4
Well, thank you very much for all the information they have provided both community and also thank you confidence management forum.
A sketch:
when I get to finish the prototype in approximately 20 days I will send you real images of the physical creation of this thanks to you who are the only ones who can get me out of this mud swamp move that leaves me like water flowing in the rivers. I’m really stuck
beforehand an affectionate greeting and again apologize for the time that this entails. thanks infinity
Really wonderful, wonderful, sublime! only detalle…voy to try to change the format of the spiral that is not copper (should not be yellow)
I think I should edit the file py right?
You do not know how much I appreciate your dedication and passion for kicad. You’re great !!, you have a good day full of good vibes
Hi Joan , I’m starting to become more familiar with the editor, I managed to replace batch many words “F.Cu” (in less than one minute) …también I created with the same code another spiral to the Bottom “B.Cu”
the question is when I want to turn the spiral in the opposite direction, what script should I write?
Thank you very very much
First of all, I too would like to express my thanks for drafting the report on this serious topic.
I was absent these days and now returning again this PCB design … Well, I see that I will be little room in the center, please, would like to see if you can send me a script code with more turns toward the center: 11 in total .
The separate (limit PCB and first Turn) is 1.5 mm.
The value of separation is 0.2 mm “turns”
values remain 0.2 thickness / diameter of 15.5 mm PCB
You are a partner of excellence
Just change the Turns value in the python script from 8 to 11, run it, safe it’s output in a txt file as per above guide and put it into your kicad_pcb file.
I know you can do it.
Okay. I see in the code that I can change the track width. I have other things to consider first before designing the inductor. I will ask here again when I start with the inductor.
As I am new to both KiCad and Python, I find myself struggling with programming to obtain the correct layout. Also as you can see, the wanted spirals are not “true” spirals. It rather looks like rounded arcs bonded by a constant straight track. Would you please guide me into how to modify your previous script to adjust the wanted layout ?
Many thanks in advance
I sort of like the spiki program.
Here a picture of a real-world application.
The product is a mass produced one-time Key generator, so every cent counts.
The screws in the back are used as some kind of electrical interface, probaby for programming the device in the factory.
The inductors on the screw terminals help in preventing ESD damage and such, together with the spark gaps below it. I find it a real beautiful design. Dave probably would have recognized it also if he wasn’t talking all the time and focusing on making his video’s.
Very spiral alike objects can be made out of half circles by cheating.
Example:
Assume you have concentric half circles with odd diameters (1, 3, 5, 7mm) on the left, and with even (2,4,6mm) on the right, then the end match up perfectly by shifting the left set 1/2mm up or downwards.
Having a separate application for Spiki (how does that PyQT stuff work?) seems a bit much. Having such a spiral inductor generator as a Footprint Wizard in KiCad itself seems to be more useful to me.
I’m also pretty green considering Python, and was surprised by:
useNLopt = True
try: # check if nlopt is available
import nlopt
except ImportError:
useNLopt = False
which suggests spiki should compile / run without the inductor estimation stuff…
came to this problem as well today and found a very pragmatic approach. Since I use Inkscape to create PCB Art from time to time I had the idea to use the spiral tool of inkscape to generate a nice spiral.
Use Inkscape to generate the spiral (by size, turns)
export as .dxf
create new part and import .dxf to layer cmts.User (set linewdth!)
import again to layer dwgs.User, mirror, put above
add vias (pads with number “~”) in center to connect top and bottom layer
add pads to start and end
save and open .mod file in text editor
replace “cmts.User” by “F.Cu” and “dwgs.User” by “B.Cu”
H together,
it is nice to learn how to make a spiral, but I’m getting interested in the oval coil shape
who can help me to know what I should modify and how to get it
