DC to DC converter
Then 0.7mm or 0.6mm trace should be fine right?
Just use a trace.
Width…? Difficult to judge from the image. You could probably calculate track resistance and compare it to the DC resistance of the inductor. If it’s a small enough fraction, should be OK.
Did you consider that the capacitance of the output capacitors is affected seriously at 12VDC due to the DC bias effect?
I did take that into account
That why 2 parallel capacitor on both end
But for out I think another one should give better margin
Guys the PCB seems to be completed fabrication and
pass electrical test too :pray:
Guys it’s here :grin:
Hmm here definitely something odd :thinking:
How much space should be kept on here
image_2023-10-18_16-28-16
Not sure what you are worried about, boards are not the best but look useable.
It sure is
What I am saying is that look at that input cap near VIN
can u see that one of cap pad is slightly out
I should have placed it carefully
