But somebody IS wrong on the internet xkcd: Duty Calls
- Check what your PCB house can do.
- While you maybe can set copper thickness in an EDA, gerber don’t have that info.
- If your not use your PCB house’s default stack, write stuff down. Else they’ll ■■■■ up for sure.
Well, yes and no. The gerber job file is part of the gerber standard although it’s pretty new. KiCad v5.99 can write the thickness to it:
"MaterialStackup": [
"Type": "Legend",
"Name": "Top Silk Screen"
"Type": "SolderPaste",
"Name": "Top Solder Paste"
"Type": "SolderMask",
"Color": "Green",
"Thickness": 0.01,
"Name": "Top Solder Mask"
"Type": "Copper",
"Thickness": 0.035,
"Name": "F.Cu"
At risk of piling in too deeply; current and heating is not the only concern. If the voltage being conducted is 1V (as in some FPGAs & CPUs) then you might not want to tolerate a 10 mV voltage drop which would be 1%. This would almost definitely add to other error sources. But if you get the same 10 mV drop in 12V then that is less than 0.1% and may well be considered negligible.
Based upon some work I am doing now…Does anyone know of an open source tool for (maybe finite element analysis) calculation of point-point resistance of copper zones? Maybe give it a gerber file and copper thickness and temperature. Specify two points and have it spit out a calculated DCR between the two points?
I just had the chance to read your comments and replies today, and I have nothing to say except that I learned plenty of new information and insights. That’s exactly what I was looking for in this platform. I will absolutely put your advice in consideration next time I am working on a big project.
Best Regards,
Omar Maaly
