Connections are not the same in schematic and pcbNew
If you have to ask that, you either didn’t read my earlier links or didn’t understand what was there.
Hi Nick,
  • Pin 1 and pin 5 in the schematic are shorted, which is why C4 is being displayed as being connected to Pin 5.
  • In the layout, there should be a connection between pin 1 and pin 5, which should solve your problem
  • You need to check if C1 is properly connected. It is important to check that the pin numbers of the schematic symbol and the component footprint symbol should match.
