Think about how I feel! Trying to learn something new, I’m completely lost frustrated and completely pissed off!
It often helps to take a break (Get a coffee, tea, beer, … but most importantly step away from the computer for at least half an hour. Believe me it helps massively.)
yea it does I assumed that’s how you did it
You were basically spoon fed by several people, within minutes of asking your question.
Yet you chose to ignore all the instructions to add PWR_FLAG
s.
What exactly do you expect?
What @kenyapcomau tried to convey is that the two power symbols (the two marked as +12V) currently create a short circuit over your switch. This means your switch right now will never be able to turn this circuit off. (use the highlight net tool on one of the wires near a +12V symbol to see what is directly connected to each other)
Sorry, I forgot to comment on this. My optional suggestion for a PWR_FLAG symbol on the output is because I suspect that you will want to use that +5V somewhere. So somewhere else on the circuit you may eventually connect an IC to the +5V. If either: the output pin of U1 isn’t a Power Output type pin (part of the symbol definition, you can check this in the symbol editor), or you don’t have a PWR_FLAG symbol on the +5V net then you will get another error like the first three that you reported.
It was an optional suggestion, and may be a little more advanced for your current skill level. My apologies if I muddied the waters by including it.
Well to be honest my patience is already quite low compared to lets say a year or two ago.
This is the reason why my first post was just a link to the FAQ, and also why my second one was a reminder to read the FAQ (in the past i would have included a bit of an TlDr as well but i simply don’t care enough any more.)
This might be part of the problem. Getting too many answers in such a short time might be too much to take in properly.
I am extremely hesitant to involve myself in this discussion… but… from his actions, regarding the previous suggestions, I suspect that @bckelly has no idea of the concept of a “power flag” and that it is unique and different from a “power symbol” (hence his assigning the 12V “symbol” to both sides of the switch after the suggestion that he needed a “power flag” on both sides of the switch.
Considering you wrote the FAQ for exactly this situation…
I think the community has been quite patient and helpful to this individual. I’m sure the mods appreciate that this didn’t go ‘way south’.
While reading this thread I got the same Idea as KingJL.
I assume bckelly is is mixing up “power symbol” and PWR_FLAG.
So I made a screenshot:
These different schematic symbols are pretty important in KiCad, and you won’t satisfy the ERC checker without also adding the “PWR_FLAG” symbols next to the “Power Symbols” in your schematic.
For more details, read the articles from the links provided earlier.
