it could be an option for k v8; v7 is already on code freezing.
Thanks for the info. Just like old trees. That“s one of a nice old tree in your avatar.
Thanks,
Itās a big, almost perfectly shaped, River Red Gum, in our back paddock.
Trunk diameter 4 meters, foliage span 41 meters, age about 600 years.
Iāve never climbed to the top to measure its height
There are a lot of very long nets between Gnd and leaves.
Thanks for the reminder. Letās see what our libraries team thinks.
Iām personally using only STEP models when adding custom 3D models (and you almost never find wrl models from manufacturers anyway). I use export to STEP on a regular basis, so thatās also all that I need.
The only thing that Iām guessing - although I donāt have evidence as I donāt know the wrl format well enough - is that wrl models may be more efficient for 3D rendering in the 3D viewer compared to STEP models. But thatās only a minor bonus if any. They also load up faster when first opening the 3D viewer and you have a very crowded board.
Depends on how it was exported by the external tool. eg: FreeCAD StepUp plugin is possible (is it? or was it?) to control the detail, which leads to more or less triangles. On current GPUs this is not an issue, maybe for (very?) old or complex boards it is.
