Maybe you can solve it with variants like we do in cadence, but where variant 0 is always the non-atomic part number, and variant 1, 2, 3 etc is whatever you need it to be when going atomic. I know my KiBOM handles variants to some extend, but maybe not fully like I suggest.
- Add these fields as default to all components: VAR1, VAR2, VAR3 …or how many you need.
- When creating a component, the Value-field will be your non-atomic part number (LM555CMMX)
- If you want to use the part in schematic non-atomic, you use it as-is.
- If you want to use the part as atomic, you delete the MPN/text in Value field and fill in the VAR1,2,3 fields as needed
- Make the BOM populate MPN based on variant number input:
 variant 0 uses Value-field as MPN,
 variant 1 uses VAR1 as MPN,
 variant 2 uses VAR2 as MPN and so on
