You can do something very similar if you assign each net with an impedance requirement to a specific netclass. You can then set DRC rules like this:
(version 1)
(rule CLASS1_F
(condition "A.hasNetclass('CLASS1')")
(layer "F.Cu")
(constraint track_width (opt 50mil))
(rule CLASS1_In1
(layer "In1.Cu")
(constraint track_width (opt 60mil))
(rule CLASS1_In2
(layer "In2.Cu")
(constraint track_width (opt 70mil))
(rule CLASS1_B
(layer "B.Cu")
(constraint track_width (opt 80mil))
And configure the router to ‘Use netclass width’, and disable ‘Track width from existing track’ (the drop-down and button shown here):
The router will then pick up the required track width every time you start a new segment. The same should work for vias, but I haven’t tried that in a while.
