Adding 3D models to the library
I’ve wondered about this also ie if you create a new custom schematic symbol you can add a footprint to it. If you can add a footprint it seems logical to me that you should also be able to add a 3D model to it, since they’re both representations of the physical device.
I assume the answer is along the lines of “because the footprint library is where all that stuff happens”. All well and good however say you assign your new custom symbol a system footprint that doesn’t have a 3D model (many dont), you dont get a 3D model in your PCB. Nor can you add one because the system footprints are read only. To get one you have to edit each of your parts in the PCB. This can be tedious, trust me I know as I use 3D export with every PCB.
Maybe the answer is to duplicate the system footprint to a custom one and add the 3D model there. All seems a bit complicated and would be easier if you could just add the 3D model to the custom schematic symbol I think.
As a matter of interest, because I’ve had to do this quite a bit I find the quickest way is to take a screen grab of the the first item you edit showing all the XYZ rotations/offsets/scales etc, then it’s easy to duplicate as you edit each one, reading from the screen grab. Luckily when you open the “file manager” to point it to your new 3D file, the file manager opens to where you loaded it last time, which saves a few clicks.
My 2 cents anyway.
I get photo-like view of each my PCB, but I have never edited any part at my PCB. If you do it for each PCB than I’m very surprised you don’t prefer to do it only once.
When in 2017 I moved to KiCad (4.0.7) I noticed 3D exists (never used 3D before) and decided to expand my documentations with PCB 3D view (just for fun).
So first what I have done (before designing my first KiCad PCB) was to make my symbol and footprint libraries. Each my symbol has footprint attached, each my footprint have 3D model attached. So I have never run through the step of footprint assigning in schematic and all footprints at my PCBs get 3D model automatically.
Soon I found that I want to use diode bridge that have no 3D model in KiCad (others had, but this (MBS) didn’t). So to make this model I learned FreeCAD to the enough level to be able to design 3D models.
Here is first 3D model I have done:
Linking 3D model to symbol has no sense, I think. Many IC symbols can use the same (like DIP14) footprint and 3D model once attached to this footprint will work for all of them. It is true until you don’t want to have 3D models with IC names written at their top, but this would probably be an exaggeration.
To say you truth I have a problem to imagine what are you writing here about. I probably newer been in those KiCad regions.
All my models are such defined that all rotations and offsets are 0.
Using 8.0.4.
You can create a local symbol and footprint library and re-map both .sch & .pcb to use these locations. Why has the KiCad team left out 3d models. The plugin does work properly in this version.
It seems if you can re-map the others, why not copy these over as well and add a link under project to the copied models ?
Thanks
For 3D, you use your OS to create folders and libraries. 3D images are then linked to footprints in the Footprint Editor.
In kicad8.99,you can now embed various elements in your schematics, pcb layouts, footprints and symbols,include the 3d model of step format
ADD 3D MODEL STP & WRL FILES
Create [“Foldername”]3D
Add 3D STP & WRL FILES to ['Foldername"]3D
Copy ['Foldername"]3D
To —>
%UserProfile%\Documents\KiCad\VER#.0\3dmodels
ADD PCB MODEL FOOTPRINT LIBRARIES TO SHARE\KICAD\FOOTPRINTS
Create [“Foldername”].pretty
Add [“3DModel.kicad.mod”] Footprints for 3D Models to Folder
Copy ['Foldername"].pretty:
To —>
%UserProfile%\Documents\KiCad\VER#.0\footprints\
ADD FOOTPRINT LIBRARIES TO KICAD THRU MAIN GLOBAL INTERFACE
Open the Main ‘Global’ Interface —>
‘Click On’ Footprint Editor
Select Top Menu Far Left Tab ‘File’ —>
In Drop Down Box Select ‘Add Library…’
BROWSE TO —>
Add [“Foldername”].pretty
@invntefx please consider removing this post. As dsa-t pointed out it is bad advice and people following it will lose their work. Those folders are read-only for a reason.
I have edited the thread post to indicate the KiCad install ‘default’
subdirectories in:
We get far too many posts of issues caused by editing the default libraries, which then get overwritten
I’ve never tried the nightly builds before but gave it a whirl and installed 8.99.
I do not see any options under EXPORT (pcb) or another option during the process for including 3D models. Could you explain how you did this in 8.99.
Thanks
I haven’t tried this yet, but here is the link to the 8.99 development features: https://forum.kicad.info/t/post-v8-new-features-and-development-news/48614/28
Thanks for the info…
I found the option and you can embed the file. Note: It would have to be done on each instance of the footprint occurrence within the design (time consuming). Due to the size of 3d models, they should really remain separate from the .pcb file (IMHO). I’m not sure if loading the .pcb also loads all 3d models. Bloating the .pcb file “may” drastically increase load time.
The symbol and footprints are automatically embedded (pretty small in size) so that’s nice for archiving. There was a plugin to extract these and place them into a directory along with changing the 3d model path, but it’s not working (I’ve filed a bug).
My original quest was to archive the design quickly and be able to send it off to the customer. This process would include just those 3d models within the design. I like the plugins functionality, but they can break. If it was part of the application, that would be less likely to happen.
Regards
glad my post inspired so many people…
maybe this is the sign there is room for such a feature to be added
Please explain this like I am a teenager. I don’t know where to get the 3d symbol(?) model(?) picture(?); where do I put it for windows 11; how do I link it? In short, how do I get it to show up in the 3d viewer. I get some components (THT), but not all. I believe some parts that are missing had been modified in footprint editor, and I get that the 3d viewer doesn’t know what I did, but others are definitely in the library that does load in. I am so confused with the info in the forum, as it still has so many previous versions that conflict with what I am seeing. Please help!
3D images can often be found attached to data sheets or components from component suppliers and manufacturers.
3D images found on the internet are stored the same way for use with your Kicad program in Windows, Apple & Linux.
You need to create a Folder with your Operating System somewhere that is Read/Write accessible.
eg. Documents. It is probably worthwhile, to allow for future expansion, to create sud-folders, inside your original Folder, to place the images; much like Kicad supplied 3D images. These sub-folders are also created with your OS.
Your path to the images you have found may look like this:
Documents > 3D_for_kicad > Connectors > an image (for a connector you have found).
  • Documents is a read/write section of your Windows11.
  • 3D_for_Kicad is the Folder you created in Documents to contain all the sub-folders.
  • Connectors is a sub-folder inside the 3D_for_kicad Folder to contain connectors.
  • an image is the 3D image for a connector you found on the internet.
Along with a Connectors sub-folder, you may eventually wish to create several/many other sub-folders. As you find images to complete your 3D PCB, create new sub-folders to suit the category of the images found.
In your PCB Editor, Right Mouse Button on the footprint and Left Mouse Button select Properties (or hotkey E). This will open the Footprint Properties Window.
The window will usually open with the “General” tab highlighted (red arrow). Select the 3D Models tab (green arrow). If a 3D image is associated, that image path will show in the 3D Model(S) box.
If there is no image, you need to associate (show the path) to the image you have placed in your eg. Documents.
To show the path, LMB click on the “+” sign (blue arrow) then LMB click on the now showing folder (magenta arrow). This will now open your Win 11.
Using the example I created above, you will now LMB click on Documents, then 3D_for_Kicad folder, then Connectors sub-folder, then “an image”, then Enter.
This whole path will now show in the box and the 3D image will show below in the “Preview”.
This FAQ, although written some time ago, is still current for Kicad 9. It helps explain 3D.
Not sure why this topic is still open after 7 months . . . it shouldn’t be.
It will close at the weekend.
Neither did I, but @Terry_Schabert asked, so I replied.
I’d intended to close this upon receiving a reply.
I’d also thought about moving the post to a new thread, but the title is still appropriate.
This topic was automatically closed after 2 days. New replies are no longer allowed.
