Apparently you have (or had) v5 libraries active when you used v6. This means that old configuration was used in new version. Just start from scratch by deleting the current v6 configuration. Where are the configuration files (settings, library tables)?
This time read the FAQ article carefully. I won’t repeat what is said there.
If the problem still persists, please tell and we’ll find out what is the problem.
