Hi!,
I edited the file so:
# -*- coding: utf8 -*-
#!/usr/bin/python
# This is derived from a cadquery script for generating QFP/GullWings models in X3D format.
# from https://bitbucket.org/hyOzd/freecad-macros
# author hyOzd
# Dimensions are from Jedec MS-026D document.
## file of parametric definitions
from collections import namedtuple
destination_dir="/generated_cap/"
# destination_dir="./"
# body color
base_color = (39,39,39)
body_color = (220,220,220)
mark_color = (39,39,39)
pins_color = (240, 240, 240)
### Parametric Values
Params = namedtuple("Params", [
'L', # overall height
'D', # diameter
'A', # base width (x&y)
'H', # max width (x) with pins
'P', # distance between pins
'W', # pin width
'modelName', # modelName
'rotation', # rotation if required
'dest_dir_prefix' #destination dir prefix
all_params_radial_smd_cap = {# Aluminum SMD capacitors
# Dimensions per http://industrial.panasonic.com/lecs/www-data/pdf/ABA0000/ABA0000PE369.pdf
"G_D100_L100" : Params( # note L model height
L =10.2, # overall height
D =10., # diameter
A =10.3, # base width (x&y)
H =12., # max width (x) with pins
P =4.6, # distance between pins
W =0.9, # pin width
modelName = 'c_el_G_D100_L100', #modelName
rotation = -90, # rotation if required
dest_dir_prefix = 'cap_El_smd'
"F_D80_L100" : Params( # note L model height
D =8., # diameter
A =8.3, # base width (x&y)
H =10., # max width (x) with pins
P =3.1, # distance between pins
W =0.9, # pin width
modelName = 'c_el_F_D80_L100', #modelName
"E_D80_L62" : Params( # note L model height
L =6.2, # overall height
D =8., # diameter
H =9.5, # max width (x) with pins
P =2.2, # distance between pins
W =0.65, # pin width
modelName = 'c_el_E_D80_L62', #modelName
"D8_D63_L77" : Params( # note L model height
L =7.7, # overall height
D =6.3, # diameter
A =6.6, # base width (x&y)
H =7.8, # max width (x) with pins
P =1.8, # distance between pins
modelName = 'c_el_D8_D63_L77', #modelName
"D_D63_L54" : Params( # note L model height
L =3.2, # overall height
D =6.3, # diameter
modelName = 'c_el_D_D63_L54', #modelName
"C_D50_L54" : Params( # note L model height
D =5.0, # diameter
A =5.3, # base width (x&y)
H =6.5, # max width (x) with pins
P =1.5, # distance between pins
modelName = 'c_el_C_D50_L54', #modelName
"B_D40_L54" : Params( # note L model height
D =4.0, # diameter
A =4.3, # base width (x&y)
H =5.5, # max width (x) with pins
P =1.0, # distance between pins
modelName = 'c_el_B_D40_L54', #modelName
And I saved as cq_params_radial_smd_cap_custom.py, but I generate it.
Thanks and regards
