I just found one in digikey and after reading datasheet, I feel its suitable choice, please could you verify once friend, I have attached the link of it to this comment.
https://www.digikey.de/en/products/detail/phoenix-contact/1731468/4482655
Well, datasheet says 400V, 24A so that should work. But with a pitch of 5mm itās a bit narrow, especially because you also need a clearance around your tracks.
This thread now also has over 40 posts in about 3 hours. I think that should be enough for today.
This is the last one, as we discussed earlier I will create a copper zone surrounding both the pins of this terminal, and connect the trace to it, and hence now pitch doesnāt matter right ?
As in pin pitch; the center-to-center spacing? It almost always matters.
Butā¦one thing I wanted to mention in the other discussion. To help handle high current, imagine a jumper (like a staple) made of bare copper wire. It interconnects two through hole pads in a track that is handling high current. This can help to increase the total copper cross sectional area and the current handling capacity. You could use a few of these in parallel if needed.
As for ābroā; there are a few women on this forum.
One last but IMPORTANT caveat. You must design spacing for 250 VAC. There are special rules which I know exist but Iāve never had the occasion to use them. This is a safety issue so I would guess its more important for your grade than overheating a trace.
You didnāt mention (that I saw) but I expect you are using one of the hall current sensors. You should look at the tech documents for said sensor and perhaps they have a recommended layout.
Wait a minuteā¦
I see a burden resistor which suggests current is measured through a current transformer. If this is correct, why does the PCB have to carry 20A ?
And this kind of Project thread is off topic for this forum . . . I know we all want to help but there are better sources out there.
This topic was automatically closed 60 minutes after the last reply. New replies are no longer allowed.
