Hi guys, someone here from the packing team could fix or point the directions to fix the Ubuntu PPA distribution?
The compilation is getting error from 1 month or more.
I’m seeing the same thing: even after updating from the repos, it shows these are the latest packages:
kicad-nightly-dbg/noble 202510260406+de628979c0~186~ubuntu24.04.1 amd64
kicad-nightly-demos/noble,noble,now 202510260406+de628979c0~186~ubuntu24.04.1 all [installed,automatic]
kicad-nightly-footprints/noble,noble 202511191718+82029cb4f~14~ubuntu24.04.1 all [upgradable from: 202511052117+a442bc1ee~14~ubuntu24.04.1]
kicad-nightly-libraries/noble,noble,now 1:202402181743+12~ubuntu24.04.1 all [installed,automatic]
kicad-nightly-packages3d/noble,noble,now 202510312119+a28d436b~13~ubuntu24.04.1 all [installed,automatic]
kicad-nightly-symbols/noble,noble 202511201918+c7391f40~10~ubuntu24.04.1 all [upgradable from: 202511082118+c8c60964~10~ubuntu24.04.1]
kicad-nightly-templates/noble,noble,now 202502190018+3ed4538~11~ubuntu24.04.1 all [installed,automatic]
kicad-nightly/noble,now 202510260406+de628979c0~186~ubuntu24.04.1 amd64 [installed]
Many of these are almost a month old.
Also trying to get this installed but the builds are still failing (Last build was 8 hours ago and failed)
new builds are up now
I installed the Ubuntu 24.04 build this morning. I haven’t given it much of a test but it appears to run properly.
Looks like it’s failing again so maybe a new issue?
The build will fail on Ubuntu any time there is a unit test failure. This happens from time to time on the nightly build, so there is no need to ping about it unless it has been stuck for a while.
