Hello all,
I have to create a symbol for a huge microprosessor that has 600pins!!!
Is it possible to split the symbol in many slices to accomodate all the pins in a more readable way?
thanks in advance,
Martín
Hello all,
thanks in advance,
Martín
Yes. You can try searching. I don’t remember all the details. There are also scripts available for things like this. People with more knowledge on how this works will show up eventually.
Parts can be multi-unit like op amp chips. Just decide on your groupings. I know one script lets you work from a spread sheet so that after you have done a cut and paste and cleaned it up, or in your case separated it by function, you just run the script.
