I have a symbol that is generic such as a USB-TypeC but not all footprints have all the pins.
For example most usb-c has A4/A9 and B4/B9 but not all footprints also include B4/B9 for Vbus
Is there a way to keep the same symbol and assigned the different footprints without getting the error that a pin does not have a corresponding pad?
How about modifying the footprint, adding two pads in a place where they do no harm (underneath/within a mounting hole for instance) and then assigning the additional pins to those?
It’s a bit of a crappy workaround IMO; I’d personally make/obtain a footprint that corresponds with the real part and its pins.
I do feel your pain though; for some connectors (and USB certainly) it almost seems like they have set up a random generator that automatically outputs the widest possible variation of physical implementations of essentially the same object.
