I have upgraded my least critical PC to 16.04 64bit to try it out and have met a few minor?? issues.
The kicad-demo package now clashes with kicad-common, it seems there are files common to both (Coldfire).
Fortunately I don’t need the demos any more, but annoying for a beginner
AMD graphics user are in trouble. Fglrx cannot be used anymore. Radeon works, but is a rather Jurassic OpenGL version
Hi, i’m a new user of both KiCAD and Ubuntu 16.04.
I had installed KiCAD from the Nightly builds PPA everything seems good but and i can’t found the ‘rounded’ pads and the other newer features, somebody else have this behavior or it’s just me?
That’s right.
And you can see how it immediately revealed the real problem, which was that you were using the latest stable release.
Unless you really need the new experimental features, stay where you are until you have gained some experience of using KiCad. I don’t like to declare new features confirmed unless they have found their way into a stable release
I’m having this same problem with not getting the daily builds after upgrading to Ubuntu 16.04 even after adding:
deb http://ppa.launchpad.net/js-reynaud/ppa-kicad/ubuntu xenial main
I seem to remember that there was a very nice search box in the latest CVPCB, and I’d really like to get it back. What repository can I add to get the daily builds again?
You are in the correct source repository.
The problem is that while the latest version of kicad nightly is 0.201604300946+6716~44~ubuntu16.04.1, the ppa webpage is wrong and points at kicad 4.0.2+dfsg1-4 (20150314 as a newer version (no GitHub access with that one either)
You have to manually override the ppa default and select the real nightly, I use Synaptic Package Manager, which makes this fairly easy to do
In the last hour, this interesting looking build has appeared
4.1.0-alpha+201605021001+6717~44~ubuntu16.04.1
Todays date and the first 4.10 build that I have seen
@davidsrsb so you mean the normal installation of this repository should be enough to get the latest?
the installation i followed was: sudo add-apt-repository ppa:js-reynaud/ppa-kicad
