The step file is pretty damn detailed and comes with almost 3.5MB. Because I have no clue how to make a more simple step from this detailed one, I just embedded it into the footprint as is.
But the resulting footprint file is only 690kB! That’s a fraction of the embedded step file. Is KiCad actively using some compression to reduce the file size of embedded files?
What is the size of the STEP file if you zip it up yourself?
You can also open the footprint in a text editor. The footprint data itself is human readable text. It probably has some metadata about how the STEP file is embedded.
