Is there a way to get 3d models via pcbnew API?
#1
I want to get a list of 3d models for each board object and then if necessary change the model reference.
It appears the Models() function returns a C++ object which I have no idea how to handle in Python. Is there a way to get a list of the model filenames, and update it?
def pcbfunc(Filename = None):
    if Filename:
        my_board = pcbnew.LoadBoard (Filename)
    else:
        my_board = pcbnew.GetBoard()
    # for v5 use GetLibItemName() instead of GetFootprintName()
    for module in my_board.GetModules():
        models = module.Models()
        print ("%s \"%s\"  " % ( module.GetReference(),
                                    module.GetValue() ))
                                    #module.GetModels() ) )
        print models
Console output:
execfile ("C:/github/kicad3Dmodels/scripts/gen_model/gen_model/gen_model.py")
REF** "WC1602A"
<Swig Object of type 'DLIST< S3D_MASTER > *' at 0x0000000021b2c990>
R1 "1000"
<Swig Object of type 'DLIST< S3D_MASTER > *' at 0x00000000219d2240>
R2 "220"
<Swig Object of type 'DLIST< S3D_MASTER > *' at 0x0000000021b2cb70>
R3 "330"
<Swig Object of type 'DLIST< S3D_MASTER > *' at 0x0000000021b2cb40>
R4 "4700"
#2
Hi bobc,
I don’t know about python, but in C++ you can check this lines:
Its gets the modules from
m_settings.GetBoard()->m_Modules
Then it checks if
!module->Models().empty()
then:
    // Get the list of model files for this model
    auto sM = module->Models().begin();
    auto eM = module->Models().end();
The filename is at
sM->m_Filename
Another example:
What is stranger is that the Models() are now a list of MODULE_3D_SETTINGS (if I am correct) and the S3D_MASTER is by a long time ago removed from the source code.
#3
Forgot to mention I was looking at 4.0.x API, I will have another look at v5 API !
For now I will probably process the file directly, later try to make it API compatible.
#4
