How to move all routes from back to front Cu
#1
I got confused and drew all traces in the back face rather than the front one.
Is there a way to move one/all traces from one plane to another without having to redraw them one by one?
I couldn’t find anything in the user interface.
Thanks
Riccardo
#2
Did you try Select.Filter.Include tracks only(all others off), then Window-Select (should be traces only), and E allows layer to be defined.
#3
You could consider a text editor :slight_smile: simply open up the board file
#4
(In OpenGL canvas:) Select the tracks. Open the Properties dialog from the context menu. Change the layer.
#5
Continuing the discussion from How to move all routes from back to front Cu:
I will try the suggestions.
Question: which file to edit?
Riccardo
#6
Edit the: “<project_name>.kicad_pcb” file.
All files in KiCad are ascii & human readable (and editable) text files.
The file formats are described here:
http://kicad-pcb.org/help/file-formats/
Edit:
I just tried @eelik 's suggestion in KiCad V4.0.7 and it works for me.
I did:
1). In PCBnew, draw some traces with “x”, on both sides, place a via with “v”.
2). End button to end the trace, Esc to exit from the trace draw funcion.
3). Drag a box around the trace segments -> Right Mouse Button -> Properties -> Layer: -> F.Cu -> OK.
#7
The suggestion from eelik worked for me too.
Thanks.
#8
