would be very nice if the default line width did not affect all layers
if i change courtyard i dont want silkscreen to be changed.
also it would be sooo nice that if you could keep the property dialog open and click on different objects without closing properties first
also you should be able to open properties even if you have chosen multiple objects and force values into properties and have all objects change, for example x and y position, regardless what their initial value was.
