Cannot connect to a pin on a symbol
I am a new user, and have one particularly pernicious bug, I have a pin I cannot connect to! Error is
Pin Not Connected" but I can drag the part and the wires SEEM to be attached. Any ideas where to start?
Although that error identifies a particular pin, the missing connection may be at some other point in the net attached to that pin. In other words - yes, when you move the component, the attached wire seems to drag along with the component. That is good. Next, look at the OTHER end(s) of that wire. Are they correctly attached to something?
If you are still having trouble, a screen shot may help us locate the problem.
Dale
