Any tips on getting multiple tracks running parallel and
Any tips on getting multiple tracks running parallel and the same angle ?
They always look unprofessional. I want same track gap and same angle.
Also a different problem I cannot extend the tracks to meet at the ends with another track.
In CAD you could use fillet or extend and trim. Not checked to see if possible, but its next on my list to sort out.
Limit to 90 and 45 deg, shove mode on interactive router may help you too (I don’t use it).
Another thing that will help is to set a grid which is large enough. With the combination of 45 and 90 degree routing, and maybe a 0.5 mm snap grid (for example) it ought to be pretty easy to get uniform angles and spacing.
Since v6 there the option of “Finish selection”
