[SOLVED]7.0.0rc1: PCM doesn't work anymore?
PCM fails for all plugins listed as the links given seem to be wrong.
Example (holds true for each plugin in the PCM):
https://github.com/openscopeproject/InteractiveHtmlBom/releases/download/v2.5.0/…’
does not exist. The problem is the …/download/…
Editing the URL and removing that works.
Can you confirm?
Works fine for me. Url you copied is cut off, that’s why it does not exist, not because of /download/
What error are you getting?
No,I just shortened it here
Just an example:
or
That’s some kind of network issue. Is your internet connection through some kind of proxy maybe? Or maybe you have a firewall that needs to add kicad.exe to exceptions?
In a pinch you can always just open the url in your browser and download the file, then install in pcm from file.
No proxy. And I didn’t change anything in my system. It’s just strange.
Sure, but that’s no the way to go, or is it?
BTW, this one works:
Yes, I’m just saying if you need a plugin NOW, there’s a workaround.
If a plugin hosted on gitlab works then maybe your local github CDN has temporary issues.
Sort of…, that’s what I came to think, too.
Thanks for your effort, however. Let’s put it to rest for now.
I also just installed InteractiveHtmlBom for V7.0-rc1
I can not run it though because there is currently some versioning problem with wxPython.
Version: 7.0.0-rc1-unknown-c5ef51d688~164~ubuntu20.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.10.1
	HarfBuzz 2.6.4
	FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, xfce, x11
	Date: Jan  7 2023 20:32:58
	Boost: 1.71.0
	OCC: 7.5.2
	Curl: 7.68.0
	ngspice: 38
	KICAD_USE_EGL=ON
	KICAD_SPICE=ON
Ok. If you like to disclose: are you in Europe? 'Cause Belgium and Austria did not work.
Just for fun I installed 6.0.2 → works.
Reinstalled 6.0.10 → fails.
7.0.0rc1 → fails.
Not sure the evidence supports the broken CDN therory, but anyways. Back to manual installations.
There is another discussion about the issue and @marekr solved it there. Thanks.
